Model: Honda VT700C Shadow
Year: 1985
Engine: Liquid cooled, four stroke, 52°V-twin,
Capacity: 745
Bore x Stroke: 79 x 76 mm
Compression Ratio: 9.0:1
Induction: 2x 36mm diaphragm-type CV
Ignition / Starting: Battery powered inductive / electric
Max Power: -
Max Torque: -
Transmission / Drive: 6 Speed / shaft
Front Suspension: 39mm Air assisted forks, 135mm wheel travel.
Rear Suspension: Dual shocks adjustable spring preload, 94mm wheel travel.
Front Brakes: 2x disc 2 piston caliper
Rear Brakes: Drum
Front Tyre: 110/90 -19
Rear Tyre: 140/90 -15
Wet-Weight: 228 kg
Fuel Capacity: 12.8 Litres
