Shadow Spirit 750 (VT750DC) - Especificações
ENGINE
Engine Type 745cc liquid-cooled 52-degree V-twin
Bore and Stroke 79.0mm x 76.0mm
Compression Ratio 9.0:1
Valve Train SOHC; three valves per cylinder
Carburetion Two 34mm diaphragm-type CV
Ignition CD with electronic advance, two spark plugs per cylinder
DRIVE TRAIN
Transmission Wide-ratio five-speed
Final Drive O-ring-sealed chain
CHASSIS / SUSPENSION / BRAKES
Front Suspension 41mm fork; 5.1-inch travel
Rear Suspension Dual shocks with five-position spring-preload adjustability; 3.2-inch travel
Front Brake Single 296mm disc with twin-piston caliper
Rear Brake Drum
Front Tire 110/80-19
Rear Tire 160/80-15
DIMENSIONS
Rake 34-degree
Trail 152mm (6.0 inches)
Wheelbase 64.8 inches
Seat Height 26.6 inches
Dry Weight 496.0 pounds
Fuel Capacity 3.6 gallons, including 1.3-gallon reserve
OTHER
Emissions California version differs slightly due to emissions equipment.
Available Colors Candy Dark Red, Black, Black/Red Pinstripe Flame, Metallic Titanium
Model ID VT750DCA
