Magna 250 - Especificações
Honda V-Twin Magna 250 2003
Category: Cruiser
Specifications
Engine
Engine Type: 249 cc, 4 Stroke - Liquid Cooled - V-Twin
Engine Bore and Stroke: 60 mm x 44 mm
Compression Ratio: 11:1
Valves DOHC, 4 valves/cylinder
Carburetion: VDD2
Ignition System: Full transistor type battery Ignition System:
Claimed Horsepower: 27 hp (20.1 kW) @ 10000 rpm
Maximum Torque: 23 Nm (17 ft. lbs) @ 7500 rpm
Type of Lubrication: Force splash combined use system
Clutch System: Wet multiple plate coil springs
Transmission type: 5 speed
Gear Ratios: 1st 2.733, 2nd 1.800, 3th 1.375, 4th 1.111, 5th 0.965
Primary Drive Ratio: 2.821
Final Drive: Belt, 2.714
Starting: Electronic
Chassis
Frame Type: Double cradle
Suspension - Front: Telescopic system
Suspension - Rear: Swing arm system
Front Fork - Rake & Trail Angles: 35 / 159 mm (6.3 inches)
Tires and Brakes
Tire - Front: 120/80-17
Tire - Rear: 150/80-15
Brakes - Front: single 250 mm disc with 2-piston calipers
Brakes - Rear: 180 mm drum
Dimensions
Overall - Length: 2315 mm (91.1 inches)
Overall - Width: 880 mm (34.6 inches)
Overall - Height: 1065 mm (41.9 inches)
Seat Height: 690 mm (27.2 inches)
Wheelbase 1620 mm (63.8 inches)
Ground clearance 130 mm (5.1 inches)
Fuel Capacity: 11 l (2.9 Gal)
Dry Weight (without fluids): 171 kg (377 pounds)
Bela moto...
só não gostei do escape...
pena que estas empresas só fazem estas motos custom de 250cc pro mercado Europeu... já que lá não tem trouxa pra comprar os lixos que vendem por aqui... :evil:
