Suzuki Boulevard S83
Category: Cruiser
Specifications
Engine
Engine: 83 cubic inch (1360cc), four-stroke, air/oil cooled, 45 degree V-twin, SOHC, 6-valves
Bore Stroke: 94.0 x 98.0mm
Compression Ratio: 9.3:1
Fuel System: (Front) Mikuni BDS36, (Rear) Mikuni BS36
Lubrication: Wet Sump
Ignition: Digital/transistorized
Transmission: 5-speed
Final Drive: Shaft Drive
Chassis
Suspension Front: Telescopic, coil spring, oil damped
Suspension Rear: Twin shock, oil damped, 5-way adjustable spring preload
Brakes Front: Single hydraulic disc
Brakes Rear: Single hydraulic disc
Tires Front: 110/90-19 62H
Tires Rear: 170/80-15 M/C 77H
Dimensions
Overall Length: 2335mm (91.9 in.)
Overall Width: 765mm (30.1 in.)
Overall Height: 1145mm (45.1 in.)
Seat Height: 740mm (29.1 in.)
Ground Clearance: 150mm (5.9 in.)
Wheelbase: 1620mm (63.5 in.)
Dry Weight: 243kg (535 lbs.)
Fuel Tank Capacity: 13 liter (3.4 gal.)
