Boulevard M109R2 - Especificações
Suzuki Boulevard M109R2
Category: Cruiser
Specifications
Engine
Engine: 1783cc, four-stroke, liquid-cooled, V-twin, DOHC, 8-valves
Bore Stroke: 112.0mm x 90.5mm
Compression Ratio: 10.5:1
Fuel System: Fuel injection
Lubrication: Semi-Dry Sump
Ignition: Digital/transistorized
Transmission: 5-speed
Final Drive: Shaft
Chassis
Suspension Front: Inverted telescopic, coil spring, oil damped
Suspension Rear: Link type, coil spring, oil damped, 7 way adjustable spring pre-load
Brakes Front: Dual hydraulic disc
Brakes Rear: Single hydraulic disc
Tires Front: 130/70R18 M/C 63V
Tires Rear: 240/40R18 M/C 79V
Dimensions
Overall Length: 2450mm (96.5 in.)
Overall Width: 875mm (34.4 in.)
Overall Height: 1185mm (46.7 in.)
Seat Height: 705mm (27.8 in.)
Ground Clearance: 130mm (5.1 in.)
Wheelbase: 1710mm (67.3 in.)
Dry Weight: 319 kg (703 lbs.)
Fuel Tank Capacity: 19.5 liter (5.2 gal.)
AugustoAmaral
Registrado em: 27 Set 2008, 15:49
semelhanças com a HD V-Rod?
Orgulho de ser Nordestino
Os Inocentes Moto Grupo
Aviaum69
Registrado em: 06 Jan 2009, 15:42
Exato!
Mais uma genérica no mercado :roll:
AugustoAmaral
Kasinski Mirage 650
Yamaha Warrior
seriam todas inspiradas na V-Rod?
ou a HD se inspirou em alguma outra?
Aviaum69
V Rod Lançamento 2001
Kasinski Mirage 650 – 2006 – inclusive já vi sites chamando ela de “V-Rod light”
Warrior – 2004 - Inclusive mencionaram que era para concorrer com a V-Rod no mercado Europeu
Agora quem se inspirou em quem não sei, mas que todas se parecem, não existe dúvida.
