Section
Item
Specification
Chassis Overall Length 97.24in
Overall Width 37.8in
Overall Height 44.69in
Wheelbase 66.54in
Ground Clearance 6.1in
Seat Height 27.17in
Rake Angle 33°
Trail 5.59in
Dry Weight 229 kg (505 lbs)
Wet Weight 244 kg (538 lbs)
G.V.W.R. 415 kg (915 lbs)
Fuel Tank Capacity 4.75gal
Tire (Front) 120/80 - 16 60H
Tire (Rear) 170/80 - 15 77H
Brake (Front) Hydraulic 4 piston caliper, 300Ø Floating Single disk
Brake (Rear) Hydraulic pin slide 2 piston caliper, 270Ø Single disk
Suspension (Front) 41Ø Conventional telescopic
Suspension (Rear) Swing arm, Hydraulic double shock absorber (preload adjustable)
Color Black, Red, White
Engine Type Liguid cooled, DOHC. 8-valves 90° V-twin
Displacement 678.2cc
Bore X Stroke 3.21 in x 2.56 in
Compression Ratio 11.5 : 1
Fuel System Fuel injection
Transmission Clutch Wet, Multi plate
Gear Constant mesh, 5 Speed
Final Drive Belt
Warranty Year 2
