ENGINE
Engine Type 1312cc liquid-cooled 52-degree V-twin
Bore and Stroke 89.5mm x 104.3mm
Compression Ratio 9.2:1
Valve Train SOHC; three valves per cylinder
Carburetion Single 38mm CV
Ignition Digital with three-dimensional mapping, two spark plugs per cylinder
DRIVE TRAIN
Transmission Five-speed
Final Drive Shaft
CHASSIS / SUSPENSION / BRAKES
Front Suspension 41mm fork; 5.1-inch travel
Rear Suspension Dual shocks with five-position spring-preload adjustability; 3.7-inch travel
Front Brake Single 336mm disc with twin-piston caliper
Rear Brake Single 296mm disc with single-piston caliper
Front Tire 140/80-17
Rear Tire 170/80-15
DIMENSIONS
Rake 32.0 degrees
Trail 144mm (5.7 inches)
Wheelbase 65.7 inches
Seat Height 27.35 inches
Dry Weight 662.0 pounds
Fuel Capacity 4.8 gallons, including 1.0-gallon reserve
OTHER
Emissions Meets current CARB and EPA emissions standards.
Available Colors Black, Titanium, Dark Red Metallic, Metallic Blue
Model ID VTX1300S
