ENGINE
Engine Type 1099cc liquid-cooled 45-degree V-twin
Bore and Stroke 87.5mm x 91.4mm
Compression Ratio 8.0:1
Valve Train SOHC; three valves per cylinder
Carburetion Two 36mm CV
Ignition Digital, two spark plugs per cylinder
DRIVE TRAIN
Transmission Five-speed
Final Drive Shaft
CHASSIS / SUSPENSION / BRAKES
Front Suspension 41mm fork; 6.3-inch travel
Rear Suspension Dual shocks with five-position spring-preload adjustability; 3.9-inch travel
Front Brake Single disc with twin-piston caliper
Rear Brake Drum
Front Tire 110/90-19
Rear Tire 170/80-15
DIMENSIONS
Rake 32-degrees 40'
Trail 152.5mm (6.0 inches)
Wheelbase 65.0 inches
Seat Height 28.7 inches
Dry Weight 556.0 pounds
Fuel Capacity 4.2 gallons, including 0.6-gallon reserve
OTHER
Emissions California version differs slightly due to emissions equipment.
Available Colors Black, Metallic Silver
Model ID VT1100C1
