ENGINE
Engine Type 745cc liquid-cooled 52-degree V-twin
Bore and Stroke 79.0mm x 76.0mm
Compression Ratio 9.6:1
Valve Train SOHC; three valves per cylinder
Induction Single 34.0mm CV type
Ignition CD with electronic advance, two spark plugs per cylinder
DRIVE TRAIN
Transmission Wide-ratio five-speed
Final Drive Shaft
CHASSIS / SUSPENSION / BRAKES
Front Suspension 41.0mm fork; 4.6-inch travel
Rear Suspension Dual shocks with five-position spring preload adjustability; 3.5-inch travel
Front Brake Single 296.0mm disc with twin-piston caliper
Rear Brake 180.0mm Drum
Front Tire 120/90-17
Rear Tire 160/80-15
DIMENSIONS
Rake 34-degree
Trail 161mm (6.3 inches)
Wheelbase 64.5 inches
Seat Height 25.9 inches
Dry Weight TBD
Fuel Capacity 3.7 gallons, including 0.9-gallon reserve
OTHER
Emissions California version differs slightly due to emissions equipment.
Available Colors Black, Candy Dark Red, Black/White, Candy Dark Red/White, Metallic Silver/Black
Model ID VT750C
