ENGINE
Engine Type 583cc liquid-cooled 52-degree V-twin
Bore and Stroke 75.0mm x 66.0mm
Compression Ratio 9.2:1
Valve Train SOHC; three valves per cylinder
Carburetion Single 34mm diaphragm-type CV
Ignition CD with electronic advance, two spark plugs per cylinder
DRIVE TRAIN
Transmission Wide-ratio four-speed
Final Drive O-ring-sealed chain
CHASSIS / SUSPENSION / BRAKES
Front Suspension 39mm fork; 5.7-inch travel
Rear Suspension Single-shock with seven-position spring-preload adjustability; 3.5-inch travel
Front Brake Single-disc with twin-piston caliper
Rear Brake Drum
Front Tire 100/90-19
Rear Tire 170/80-15
DIMENSIONS
Rake 35-degree
Trail 161mm(6.3 inches)
Wheelbase 63.0 inches
Seat Height 25.6 inches
Dry Weight 458.0 pounds
Fuel Capacity 2.9 gallons, including 0.9-gallon reserve
OTHER
Emissions California version differs slightly due to emissions equipment.
Available Colors Candy Dark Red, Light Pearl Blue Metallic
Model ID VT600CD
