Designation: NRX1800
ENGINE AND DRIVETRAIN
Engine Type: Liquid-cooled horizontally -opposed six
Valve arrangement: SOHC; two valves per cylinder
Bore and Stroke, displacement: 74 x 71mm, 1832cc
Compression Ratio: 9.8:1
Carburetion: PGM-FI
Transmission: Five speeds
Final Drive: Shaft
CHASSIS
Wheelbase: 68.9 inches
Dry Weight: 769.6 pounds
Front suspension: Trailing bottom-link; 3.9 inches of travel
Rea suspension: Single shock; 3.9 inches of travel
Front brake: 2, double-action 3-piston calipers, full-floating 13-in. discs
Rear brake: Double-action two-piston caliper, 13.2-in. disc
Front tire: 150/60R-18 tubeless radial
Rear tire: 180/55R-17 tubeless radial
Seat Height: 27.2 inches
Fuel Capacity: 6.2 gallons
