Engine: 90 cubic inch, four-stroke, air/oil cooled, 45 degree V-twin, SOHC, 6-valves
Bore Stroke: 96.0 x 101.0mm
Compression Ratio: 8.5:1
Fuel System: Fuel Injected
Lubrication: Wet Sump
Ignition: Digital
Transmission: 5-speed
Final Drive: Shaft Drive
Overall Length: 2525mm (99.4 in.)
Overall Width: 1000mm (39.4 in.)
Overall Height: 1030mm (40.6 in.)
Seat Height: 700mm (27.6 in.)
Ground Clearance: 140mm (5.5 in.)
Wheelbase: 1700mm (66.9 in.)
Dry Weight: 302kg (665 lbs.)
Suspension Front: Telescopic, coil spring, oil damped
Suspension Rear: Link-type, oil damped, 5-way adjustable spring preload
Brakes Front: Dual hydraulic disc
Brakes Rear: Single hydraulic disc
Tires Front: 150/80-16
Tires Rear: 180/70-15 M/C
Fuel Tank Capacity: 14.0 liter (3.7 gal.)
Color: White/Silver, Black/Red
