Shadow Sabre - Especificações
ENGINE
Engine Type 1099cc liquid-cooled 45-degree V-twin
Bore and Stroke 87.5mm x 91.4mm
Compression Ratio 8.0:1
Valve Train SOHC; three valves per cylinder
Carburetion Two 36mm CV
Ignition Digital, two spark plugs per cylinder
DRIVE TRAIN
Transmission Five-speed
Final Drive Shaft
CHASSIS / SUSPENSION / BRAKES
Front Suspension 41mm fork; 4.7-inch travel
Rear Suspension Dual shocks with five-position spring-preload adjustability; 3.9-inch travel
Front Brake Single 316mm disc with twin-piston caliper
Rear Brake Single 276mm disc with single-piston caliper
Front Tire 120/90-18
Rear Tire 170/80-15
DIMENSIONS
Rake 32.7 degrees
Trail 161.0mm (6.3 inches)
Wheelbase 64.6 inches
Seat Height 27.2 inches
Dry Weight 577.0 pounds
Fuel Capacity 4.2 gallons, including 0.6-gallon reserve
OTHER
Emissions California version differs slightly due to emissions equipment.
Available Colors Candy Black Cherry, Black/Flame
Model ID VT11C2
