Boulevard M50 - Especificações
Engine: 50 cubic inch, four-stroke, liquid cooled, 45 degree V-twin, SOHC, 8-valves, TSCC
Bore Stroke: 83.0 x 74.4mm
Compression Ratio: 9.4:1
Fuel System: Fuel Injection
Lubrication: Wet Sump
Ignition: Digital
Transmission: 5-speed
Final Drive: Shaft Drive
Overall Length: 2370mm (93.3 in.)
Overall Width: 920mm (36.2 in.)
Overall Height: 1125mm (44.5 in.)
Seat Height: 700mm (27.6 in.)
Ground Clearance: 140mm (5.5 in.)
Wheelbase: 1655mm (65.2 in.)
Dry Weight: 247kg (544 lbs.)
Suspension Front: Inverted, telescopic, coil spring, oil damped
Suspension Rear: Link-type, oil damped, 7-way adjustable spring preload
Brakes Front: Single hydraulic disc
Brakes Rear: Single drum
Tires Front: 130/90-16
Tires Rear: 170/80-15
Fuel Tank Capacity: 15.5 liter (4.1 gal.)
Color: Blue, Black
M50 Limited Edition - Especificações
Ignition: Digital
Color: Blue, Black
AugustoAmaral
Registrado em: 27 Set 2008, 15:49
Seria a nossa M800?
Orgulho de ser Nordestino
Os Inocentes Moto Grupo
