Make Model: Suzuki VS 800GL Intruder
Year: 1992
Engine: Liquid cooled, four stroke, 45°V-Twin, SOHC, 4 valves per cylinder.
Capacity: 805
Bore x Stroke: 83 x 74.4 mm
Compression Ratio: 10.0:1
Induction: Mikuni BDS36
Ignition / Starting: Digital transistorized
Max Power: 55 hp 40.1 kW @ 7000 rpm (rear tyre 49.5 hp @ 7100 rpm )
Max Torque: 64 Nm @ 5000 rpm
Transmission / Drive: 5 Speed / Shaft
Front Suspension: Telescopic coil spring, oil damped
Rear Suspension: Swingarm, oil damped, 5-way adjustable spring preload
Front Brakes: Single 310mm disc 2 piston calipers
Rear Brakes: Single drum
Front Tyre: 80/90-19
Rear Tyre: 140/90-15
Dry-Weight / Wet-Weight: 201 kg / 212 kg
Fuel Capacity: 12 Litres
Consumption average: 16.9 km/lit
Braking: 60 - 0 / 100 - 0
14.8 m / 41.9 m
Standing ¼ Mile:
13.6 sec / 153.8 km/h
Top Speed: 164.6 km/h
