Model: Honda VT 500C Shadow
Year: 1983
Engine: Liquid cooled, four stroke, 52°V-twin, SOHC, 3 valves per cylinder.
Capacity: 491
Bore x Stroke: 71 x 62 mm
Compression Ratio: 10.5:1
Induction: 2x 32mm Keihin carbs
Ignition / Starting: Electronic / electrical
Max Power: 47.5 hp 34.6 kW @ 9000 rpm
Max Torque: 42 Nm @ 7000 rpm
Transmission / Drive: 6 Speed / shaft
Front Suspension: Air assisted telescopic forks.
Rear Suspension: Pivoted fork dual adjustable shocks
Front Brakes: Single disc 2 piston caliper
Rear Brakes: Drum
Front Tyre: 100/90-18
Rear Tyre: 130/90-16
Dry-Weight: 180 kg
Fuel Capacity: 12.5 Litres
