VRSCAW V-Rod - Especificações
- Administrador
Harley-Davidson VRSCAW V-Rod 2007
Category: Cruiser
DIMENSIONS (U.S. UNITS)
Length: 94.4 in.
Seat Height
Laden: 26.0 in.
Unladen: 27.1 in.
Ground Clearance: 5.0 in.
Rake Steering Head/Trail: 34.0º / 4.5 in.
Wheelbase: 67.2 in.
Fuel Capacity: 5.0 gals.
Oil Capacity: 4.5 qts.
Weight
Dry Weight: 637.0 lbs.
Running Order: 670.0 lbs.
POWERTRAIN
Engine: Liquid-cooled, Revolution®
Displacement: 69.0 in.³ (1,130cc)
Bore x Stroke: 3.94 in. x 2.84 in.
Engine Torque: 74.0 ft. lbs. @ 7000 rpm
Fuel System: Electronic Sequential Port Fuel Injection (ESPFI)
Compression Ratio: 11.3:1
Miles per Gallon
Carb.: N/A
ESPFI: 47.7 hwy / 37.4 city
Primary Drive: Gear
Gear Ratio (overall)
1st: 11.752
2nd: 7.898
3rd: 6.322
4th: 5.459
5th: 4.899
6th: N/A
WHEELS/TIRES
Wheels
Front: Slotted Machined Cast Aluminum Disc
Rear: Slotted Machined Cast Aluminum Disc
Tire Size
Front: 120/70ZR-19 60W
Rear: 240/40R-18 79V
CHASSIS
Brakes
Front: 4-piston
Rear: 4-piston
Lean Angle (per SAEJ1168): 32º / 32º
Exhaust System: Chrome, slash-cut duals
