Engine
Engine Type Four-Stroke, Single Cylinder
Displacement 249 cc
Bore & Stroke 77 x 53.6mm
Compression Ratio 11.5:1
Fuel System Carbureted
Ignition CDI
Transmission 6-speed
Drive Train Chain Drive
Cooling Liquid
Horse Power 27 HP
Fuel Tank Capacity 3 gallons
Battery 12 volts 9 amp
Dimension
Overall Length 78.3 in.
Overall Width 32.5 in.
Overall Height 40.9 in.
Seat Height 31.5 in.
Ground Clearance
Front Tire 100/70-17
Rear Tire 130/70-17
Wheelbase 53.1 in.
Dry Weight 242 lbs
Suspension
Front Suspension Telescope Suspension
Rear Suspension Mono-shock Absorber
Brake
Front Brake Hydraulic Disc
Rear Brake Hydraulic Disc
Other
Color Black, Red, Yellow
Warranty 18 Months Limited Warranty
Referência: http://www.bennche.com/product/Megelli_ ... hlight.htm
