Intruder M1800R - Especificações
DIMENSIONS AND WEIGHTS
Overall length: 2480mm (97.6in)
Overall width: 875mm (34.4in)
Overall height: 1185mm (46.7in)
Wheelbase: 1710mm (67.3in)
Seat height: 705mm (27.8in)
Dry Mass: 319kg (703.3lbs)
Fuel capacity: 19.5litres (4.3gallons)
ENGINE SPECIFICATIONS
Engine capacity: 1783cc
Engine: Four stroke, liquid-cooled, DOHC, 54° V-twin
Bore: 112mm x 90.5mm
Compression ratio: 10.5 : 1
Lubrication: Semi-dry sump
Ignition: Electronic ignition (Transistorised)
Fuel system: Fuel Injection
Starter: Electric
Transmission: 5-speed constant mesh
Drive: Shaft Drive
CHASSIS SPECIFICATION
Front suspension: Inverted telescopic, coil spring, oil damped
Rear suspension: Link type, coil spring, oil damped
Front brakes: Disc brake, twin
Rear brakes: Disc brake
Front tyres: 130/70R18 M/C 63V tubeless
Rear tyres: 240/40R18 M/C 79V tubeless
Imagem Imagem
