2007 Yamaha DragStar 400
Category: Cruiser
Also called:
Yamaha DragStar Four
Yamaha DS4
Specifications:
Engine
Model: H601E
Type: Air cooled 4 strokes SOHC 2 valves
Cylinder: V type 2
Displacement: 399cc
Bore x stroke: 68.0mm × 55.0mm
Compression ratio: 9.7 : 1
Maximum power: 24kW (32PS) @ 7,500rpm
Maximum torque: 32N m (3.3kgf m) @ 6,000rpm
Starting system: Cell system
Lubricating system: Forced force wet sump
Carburetor type: BDS28×2
Ignition system: T.C.I. Formula
Powertrain
Primary drive: Gear, ratio = 2.028 (71/35)
Final drive: Shaft, ratio = 3.070 (19/18×32/11)
Clutch type: Wet multiple plate coil springs
Transmission type: Return type 5 step
Change gear ratio:
1st: 2.714
2nd: 1.900
3rd: 1.458
4th: 1.166
5th: 0.966
Chassis
Frame type: Double cradle
Caster/trail: 35°00 ‘/153mm
Front brake: Hydraulic type single disk
Rear brake: drum
Front tire: 100/90-19M/C 57S
Rear tire: 170/80-15M/C 77S
Dimensions/weight/capacity
Length: 2,340mm
Width: 840mm
Height: 1,065mm
Wheelbase: 1,610mm
Seat height: 660mm
Dry weight: 209kg
Weight equipped: 225kg
Minimum turning radius: 3.1m
Motor oil capacity: 3.2L
Fuel tank capacity: 15L
Fuel economy: 43.0km/L @ 60kph
Electricals
Battery capacity/type: 12V-10Ah (10h)/GT12B-4 (MF)
Headlight: Halogen valve (60W/55W)
Available only in:
Japan
