Engine Four-stroke, air/liquid-cooled, SOHC, four valves per cylinder, V-twin
Displacement 1,552cc / 95ci
Bore x stroke 102.0mm x 95.0mm
Compression ratio 9.0:1
Cooling Liquid
Induction Digital fuel injection with dual 36mm throttle bodies
Ignition TCBI with digital advance
Transmission Five-speed
Final Drive Shaft
Frame High-tensile steel, double cradle
Rake / trail 32 degrees/ 6.6 in.
Front suspension / wheel travel 41mm hydraulic fork / 5.9 in.
Rear suspension / wheel travel Dual air-assisted shocks / 3.7 in.
Tire, front 130/90 x 16
Tire, rear 170/70 x 16
Brakes, front / rear Dual 300mm hydraulic discs / 300mm disc
Overall length 98.6 in.
Overall width 40.9 in.
Overall height 44.5 in.
Ground clearance 5.1 in.
Seat height 27.4 in.
Dry weight 675 lbs.
Fuel capacity 5.3 gal.
Wheelbase 66.1 in.
Colors Ebony, Two-Tone Candy Cardinal Red / Metallic Phantom Silver
Warranty 12 months
Good Times™ Protection Plan 12, 24, 36 or 48 months
