Made in China
Bom amigos,
Descubri um site chamado made-in-china.com que tem uma centena de fabricantes, revendas e distribuidores de motos chineses, não consegui entender bem quem fabrica, quem revende e etc... então vou listar os modelos que encontrei em alguns deles e mencionar a fonte... :idea:
Tuohe Enterprise Group Limited
250CC Motorcycle with EEC Certificate (TH250-B)
Product Description
1) Dimensions: 2,170*840*1,140mm
2) Wheel base: 1,465mm
3) Ground clearance: 135mm
4) Complete vehicle kerb mass: 148kg
5) Max. Weight: 150kg
6) Engine model: 162FMJ
7) Tire specifications:
A) Front: 110/90-16 b) Rear: 130/90-15
8) Ignition: CDI
9) Start: Kick/electric
10) Brake mode: Drum/disc
11) The latest structure racing grade muffler with oil-saving engine
Outer packing:
Carton dimensions: 2, 000*560*860mm
Standard: TH250-B
Motorcycle with EPA & DOT (CF250T-5)
Product Description
CF250T-5 @ EEC Type Approval No. E4*2002/24*0472*00
Dimension: 2225mm*875mm*1110mm Wheel Base (mm): 1490mm
Ground Clearance: 150mm Dry Weight: 166kg
Max. Load: 150kg Turning Radius: 5. 0m
Front Tire & Pressure: 100/90-18 (250kpa) Front Brake: Disk Hand Control
Rear Tire & Pressure: 150/80-15 (280kpa) Transmission: CVT
Fuel Tank Capacity: 17L Bore * Stroke: 72mm*60mml
Engine: 172MM-A Engine Type: Vertical, Single Cylinder, 4 Stroke, liquid cooled
Fuel: Octane 90 or above Displacement: 244ml
Starting: Electrical Start Lubrication Oil: SAE 15W-40/SF
Brake Distance: ≤7. 0m (V=30km/h) Fuel Consumption: ≤3. 1L/100km
Maximum Speed: 100km/h GR AB: ≥16 degree
Qty in 40 GP: 34units
Trademark: CF250T-5
Model: CF250T-5
TH150-6 MOTO
Product Description
TECHNICAL DATA: (TH150-6)
Specifications:
1) Dimensions (L x W x H): 2,145 x 770 x 1,135mm
2) Piston displacement: 150cc
3) Max. speed: 90km/h
4) Max. loading capacity: 150kg
5) Wheelbase: 1,485±15mm
6) Ground clearance: 150±15mm
7) Fuel capacity: 13.8L
8) Seat height: 800mm
9) Started system: kick / electric
10) Tire size: 100/90-16-4PR, 130/90-15-6PR
11) Wheel type: light alloy
12) Brake mode: disc brake / drum brake
13) Brake operation mode: hand / foot brake
250CC Motorcycle (TH250-A)
Product Description
1) Dimensions: 2, 170 x 840 x 1, 140mm
2) Wheel base: 1, 465mm
8) Ignition: CDI
9) Start: Kick / electric
10) Brake mode: Drum / disc
Outer packing:
Carton dimensions: 2, 000 x 560 x 860mm
Model: TH250-A
125cc Police Motorcycle (DY125-12)
Product name: 125CC MOTORCYCLE
Product code: DY125-12
Product Explanation:
Product Information Product Type: DY125-12
Product Size: Size: 2200 X 790 X 1120 (mm)
Factory: Guangzhou
Explain: Wheel Base: 1470 (mm)
Net Weight: 155 (kg)
Type Of Engine: 1cylinder, wind cool, 4stroke
Max.Speed: >= 90km/h
Rated power and the relevant rotate speed: 6.9/7500 (kw/r/min)
Model: DY125-12
Standard: DY125-12
250cc Motorcycle (YY250-2)
Product Description
ENGINE TYPE: 253FMM
Discharge: 250CC
Approved: EEC
Dry Weight: 145 kg
Wheel Base: 1468mm
Exterior Size: 2150x780x1020mm
Maxiumu Speed: 90km/h
Maximum Payload Mass: 150kg
Fuel Capacity: 13L
Brake Type: F: Disk; R: Disk
Engine Type: 4 stroke; Single; Air-forced cool
Maximum Power: 9.8kw/8500r/min
Starting System: Electric/Kick
Tyre Size: 90/90-17 130/90-15
Battery Size: 12V/7AH
Trademark: TUOHE
Model: YY250-2
250cc Motorcycle (TH250-3W)
Product Description
Dimension: 2200 mm*1020mm*1120mm Wheel Base (mm): 1480mm
Groud Clearance: 150mm Dry Weight: 208kg
Max. Load: 170kg Turning Radius: 5. 0m
Rear Tire & Pressure: 150/80-15 (280kpa) Rear Brake: Disk Hand Control
Fuel Tank Capacity: 12L Transmission:
Engine: 172MM-A Engine Type: 2 Cylinder, 4 Stroke, Air cooled
Brake Distance: ≤7. 0m(V=30km/h) Fuel Consumption: ≤3. 0L/100km
Qty in 40GP: 22 units
Model: TH250-3W
Standard: EEC EPA DOT
Geely Group Zhejiang Motorcycle Co., Ltd.
250cc Motorcycle (JL250-2)
Product Description
Overall Size (mm) 2190 *740*1080
Wheel Base (mm) 1460
Ground Clearance (mm) 120
Dry Weight (kg) 146
Max. Speed (km/h) 90
Max. Load (kg) 140
Wheel Size Front: 3. 00-18, Rear: 130/90-15
Brake Type Front: Disc, Rear: Drum
Engine Model 250cc 4 Stroke, Air Cooled, Twin Cylinder
Starting Mode Electric And Kick Start
Model: JL250-2
250CC Motorcycle (JL250-2C)
Product Description
Overall Size (mm) 2125 *860*1080
Ground Clearance (mm) 140
Dry Weight (kg) 154
Max. Load (kg) 140
Trademark: Geely
Model: JL250-2C
Motorcycle (JL150-13)
Product Description
Overall size (mm) 2220*830*1130
Wheel base (mm) 1455
Net weight (kg) 158
Max Torque 10Nm/7500r/min
Fuel tank capacity 10L
Bore*stroke mm 62*49.5
Actual displacement 149.5ml
Start method Electric/kick starter
Clutch type Wet,multi-plate
Lubrication type Pressing&splashing
Rated power 7.5kw(8000r/min)
Maximum power 9.0kw(8500r/min)
Brake Distane: <7m
Maximum speed 85km/h
Economic oil consumption <=2.1L/100km
Climbing Capacity >=20
Trademark: GEELY
Model: JL150-13
Link
Wuxi Yunlu Motorcycle Co., Ltd.
150cc Motorcycle (YL150-9)
Product Description
Displacement/powr(ml/kw):149/8.0
Dimension(L*W*H):2140*820*1120
Axle base(mm):1350
Max loading(kg):150
Max speed(km/h):85
Net weight(kg):128
Engine:Single-cylinder,4-stroke,air-cooling
Ignition: CDI
Starting system: Electric/Kick-back starting
Brake:(F)disk,(R)Drum
Trademark: YUNLU
Model: YL150-9
Productivity: 5000pcs/month
150cc Motorcycle (YL150-5)
Product Description
we are vehicle manufacturer in China,specializing in a wide selection of motorcycles,scooter,electric bikes.
Displacement(ml): 124
Overall size(L*W*H): 1990*820*1130
Axle base(mm): 1330
Max loading(kg): 150
Max speed(km/h): 90
Net weight(kg): 128
Engine: Single-cylinder, 4-stroke, air-cooling
Ignition: CDI
Brake: (F)disk, (R)Drum
Trademark: YUNLU
Model: YL150-5
Cruiser 150cc (YL150-8A)
Product Description
Model:YL150-8A
Specfication:
Displacement/Power(ml/kw):149.0/8.0
Dimension(L*W*H):2260*850*1100
Axle base(mm):1480
Max loading(kg):150
Max speed(km/h):90
Net weight(kg):156
Ground Clearance(mm) :140
Ignition: CDI
if you are interested in our products ,please contact me: wxlmt()hotmail.com
Trademark: YUNLU
Model: YL150-8A
Novel Cruise 150cc Motorcycle(YL150-12)
Product Description
Nevel models of cruise, if you are interested in it, please contact us
Model: YL150-12
Displacement/Power(ml/kw): 149. 0/8. 0
Dimension(L*W*H): 2150*850*1120
Axle base(mm): 1450
Max speed(km/h): 90
Net weight(kg): 143
Ignition: CDI
Brake: (F)Disk, (R)Drum
Trademark: YUNLU
Model: YL150-12
Motorcycle (YL250)
Product Description
SPECIFICATION:
Dimension(L*W*H):2150*850*1120(mm)
Axle base(mm):1450
Max load(kg) :150
Max speed(km/h) :95
Net weight(kg):153kg
Ground clearance: 140mm
Engine :Double cylinder,4 stroke, air-cooling
Ignition: CDI
Starting system: electric starting
Brake:(F)disc (R)drum
Tire size: (F)3.00-18 (R)130/90-15
Trademark: YUNLU
Model: YL250
Cruise 250cc Motorcycle (YL250-2)
Product Description
Model: YL250-2
Specification:
Dimension(L*W*H): 2092*895*1095(mm)
Axle base(mm): 1437
Max load(kg): 150
Max speed(km/h): 90
Net weight(kg): 155kg
Engine: Double cylinder, 4 stroke, air-cooling
Engine model: 253FMM
Ignition: CDI
Starting system: Electric starting
Brake: (F)disc (R)drum
Trademark: YUNLU
Model: YL250-2
Cruiser Motorcycle (250cc)
Product Description
Model: YL250-A
Specification:
Dimension(L*W*H): 2150*850*1120(mm)
Axle base(mm): 1450
Max load(kg): 150
Max speed(km/h): 95
Net weight(kg): 153kg
Engine model: 253FMF
Ignition: CDI
Trademark: YUNLU
Model: YL250-A
Zengcheng Benma Industrial Co., Ltd.
Motorcycle (SL150-6)
Product Description
Dimension(mm): 2210*860*1170
Max. Speed(km/h): ≥90
Wheel Base(mm): 1495
Start Method: Kick/Electric Start
Displacement(ml): 149
Unloaded Weight(kg): 152
Engine Type: 1-Cylinder, Air-cooled, 4-Stroke
Max. Power[kw/(r/min)]: 7. 5/8000
Model: SL150-6
Motorcycle (SL150-4)
Product Description
Dimension(mm): 2190x780x1160
Max. Speed(km/h): 90
Wheel Base(mm): 1470
Displacement(ml): 149 Unloaded Weight(kg): 135
Max. Load(kg): 165
Tires Type: Front Wheel: 110/90-16
Rear Wheel: 130/90-15
Max. Torque[N. M/(r/min)]: 9. 8/7500
Max. Power[kw/(r/min)]: 9. 0/8500
Fuel Tank Volume(l): 17
Economic Fuel Consumption(1/100km): 2. 2
Model: SL150-4
Essa empresa parece vender a Aquila 250, ou Hyosung GV 250 com outro nome... :idea: :roll:
250CC Motorcycle (SL250)
Product Description
Dimension(mm): 2215*780*1140
Max. Speed(km/h): ≥85
Wheel Base(mm): 1490
Start Method: Electric start
Displacement(ml): 248
Unloaded Weight(kg): 137
Max. Load(kg): 150
Front Wheel: 3. 0-18
Engine Type: 2-Cylinder, V-type, Air-cooled, 4-Stroke
Max. Torque[N. M/(r/min)]: 22/8000
Max. Power[kw/(r/min)]: 17/8000
Fuel Tank Volume(l): 12
Economic Fuel Consumption(1/100km): ≤2. 4
Model: SL250
Shineray
Parece que já esta à venda no Brasil...
http://www.shineray.com.br/
Site do fabricante: http://www.shineray.com/html/
XY250-2
ENGINE
Engine 253FMM
Displacement (ml) 233
Bore×Stroke(mm): 53×53
Compression Ratio: 9.2:1
Max Power (km/r/min): 13.0/8500
Starter Electric start
Clutch: Manual
Chassis Dimension(L×W×H)(mm) 2380×860×1230
Wheel Base(mm) 1590
Braking Mode(front/rear) double discs/drum
Front Tyre Size 110/90-16
Rear Tyre Size 130/90-15
Seat Height(mm) 750
Ground Clearance(mm) 160
Net Weight(kg) 158
XY150-6-IIA
Dimension(L×W×H)(mm) 2245×760×1195
Wheel Base(mm) 1480
Net Weight(kg) 156
Max.Load(kg) 150
Spark Plug D8TC
Spark Plug Gap 0.6-0.8
Front Tyre Size 100/90-16
Compression Ratio 9.0:1
Standard Power(kw/r/min) 8.8/8500
Max.Torque(N.m/r/min) 10.5/7000
Max.Speed(km/h) ≥85
Bore×Stroke(mm) 62.0×49.5
Idle Speed(r/min) 1500
Brake Distance(30km/h) ≤7.00m
Displacement(ml) 149.4
Engine 161FMJ
Climbability ≥20°
XY150II-A
Dimension(L×W×H)(mm) 2070×830×1150
Wheel Base(mm) 1325
Net Weight(kg) 120
Max.Load(kg) 150
Spark Plug D8TC
Front Tyre Size 2.75-18
Rear Tyre Size 3.25-18
Standard Power(kw/r/min) 8.0/9000
Max.Torque(N.m/r/min) 10.0/7500
Max.Speed(km/h) ≥85
Engine 161FMJ
Climbability ≥18o
XY150-3
Dimension(L×W×H)(mm) 2180×820×1155
Wheel Base(mm) 1375
Net Weight(kg) 142
Max.Load(kg) 150
Spark Plug D8TC
Front Tyre Size 110/100-16
Rear Tyre Size 110/90-16
Max.Speed(km/h) ≥85
Engine 161FMJ
Climbability ≥18o
tem cada moto aí que entraria facilmente na categoria "motos esquisitas" hehehhehe :lol:
São poucas as com motor V2, e achei muito interessante aquele mini triciclo...
Agora, é impressionante a quantidade de fabicas dessas motos, só não se sabe se vão durar tanto quanto as italianas ou faponesas e depois deixar meio mundo na mão..
Não entendi essa!!!
A Mirage/Aquila não é coreana!?
A SL250 é chinesa!? O motor não parece ter o nome da Younsung, sem bem que isso parece tudo OEM
Cros,
Seu comentário é sobre a SL250 certo?
Eu também fiquei totalmente na dúvida quando vi isso... e não sei reponder sua pergunta... a Hyosung é sim Koreana e fabrica a GV250 como foi existir a SL 250 na China, não faço idéia...
Sobre seu comentário sobre mercado, vale lembrar que estamos falando do mercado Chinês com mais de 1 bilhão de consumidores... o resto do mundo já é resto... rsrsrsrsrs
Pelo jeito os chineses não ligam muito pra beleza não....a maioria é muito feia.. :lol:
