Polaris Victory Hammer
Engine Type 4-stroke 50° V-Twin
Cooling System Air/Oil
Displacement 100 ci/1634cc
Bore x Stroke 101x102mm
Compression Ratio 8.7:1
Valve Train Single overhead camshafts with 4 valves per cylinder, self-adjusting cam chains, hydraulic lifters
Fuel System Electronic Fuel Injection with 45mm throttle bodies
Fuel Capacity 4.5/17.0 U.S. gallons/liters
Exhaust Staggered slash-cut dual exhaust with crossover
Oil Capacity 5.0qts/4.75ltr
Charging System 38 amps max output
Battery 12 volts/18 amp hours
