Lifan - LF200-18 - Especificações
- Administrador
2008 Lifan LF200-18
Category: Cruiser
Specifications
Engine
Model: 2V50ML
Type: V-twin cylinder, water-cooled, 4-stroke
Bore×Stroke: 50 x 49.5mm
Displacement: 194.4 cc
Maximum Power: 12 kw @ 8500 rpm
Maximum Torque: 14 N.m @ 6000 rpm
Clutch: Wet multi-plate
Lubrication: Pressure/splash
Start: Electric start/kick start
Ignition: TCI
Transmission: 5 gear
Maximum Speed: 100 kph
Fuel Consumption: ≤ 2.3L/100km
Chassis
Front brake: Disk
Rear brake: Drum
Front Tire: 110/90-16
Rear Tire: 130/90-15
Dimensions
L×W×H : 2400 x 850 x 1150 mm
Wheel base: 1635 mm
Minimum Ground Clearance: 175 mm
Dry Weight: 170kg
Height Of Seat: 750 mm
Fuel Tank Capacity: 14 L
- Registrado em: 25 Abr 2008, 16:59
que beleza de moto...pq a DAFRA naum traz essa???
" gonzo, el loco"
Questão de tempo, a crise freou as itenções de muitas empresas, a Lifan ainda esta procurando parceiros no Brasil a nota ainda esta no site da Câmara de Comércio e Indústria Brasil-China
http://www.ccibc.com.br/pg_dinamica/bin ... id_pag=249
