Loncin - LX250-8 - Especificações
Moto: Amazonas AME
Moderadores: Moderadores, Administradores, Colaboradores Amazonas
Model LX250-8
Engine Type One cylinder,4 stroke,air-cooled
Bore×Stroke (mm) 72.0×61.2
Piston Displacement (cc) 249.2
Compression Ratio 8.9:1
Max. Power (kw/rpm) 14.5/8 500
Max. Torque (N.m/rpm) 18.0/6 000
Transmission System Chain Drive
Ignition Type C.D.I.
Starter System Electric
Transmission 5 Speed
L×W×H (mm) 2200×830×1200
Wheel Base (mm) 1500
Ground Clearance (mm) 200
Dry Weight (kg) 185
Brake (Front/Rear) Disk/Drum
Tyre, Front 110/90-16/250
Tyre, Rear 130/90-15/280
Fuel Tank Capacity (L) 20
Engine Oil Capacity (L) 1.3
Max. Load Capacity (kg) 150
Max. Speed(km) 120
Battery(V/Ah) 12V/9Ah
loading(20'/40') 18/45
