Engine Type 4-stroke 50° V-Twin
Cooling System Air/Oil
Displacement 106 ci/1721 cc
Bore x Stroke 101x102mm
Compression Ratio 9.4:1
Valve Train Single overhead camshafts with 4 valves per cylinder, self-adjusting cam chains, hydraulic lifters
Fuel System Electronic Fuel Injection with 45mm throttle bodies
Fuel Capacity 6.0/22.7 ,Reserve 1.0/3.8 U.S. gallons/liters
Exhaust Split dual exhaust with crossover
Oil Capacity 5.0qts/4.75ltr
Charging System 50 amps max output
Battery 12 volts/18 amp hours
Vision Street Tour
http://www.polarisindustries.com/en-us/Victory/
