Especificações
Engine 1462cc, 4-stroke, 2-cylinder, Liquid-cooled, SOHC, 54-degree V-twin
Bore x Stroke 96.0 mm x 101.0 mm (3.78 in x 3.98 in )
Compression Ratio 9.5 : 1
Fuel System Suzuki Fuel Injection
Starter Electric
Lubrication Wet sump
DRIVETRAIN
Transmission 5-speed constant mesh
Final Drive Shaft Drive
CHASSIS
Suspension Front Telescopic, coil spring, oil damped
Suspension Rear Link type, coil spring, oil damped
Brakes Front Disc brake
Brakes Rear Disc Brake
Tires Front 130/80-17M/C 65H, tubeless
Tires Rear 200/60-16M/C 79H, tubeless
Fuel Tank Capacity 4.8 US
Color Glass Sparkle Black
ELECTRICAL
Ignition Electronic ignition (Transistorized)
DIMENSIONSANDCURBWEIGHT
Overall Length 2560 mm (100.8in)
Overall Width 990 mm (39 in)
Wheelbase 1,675 mm (65.9 in)
Seat Height 720 (28.3 in)
Curb Weight 800 lbs
