Confederate - X132 Hellcat Combat: Especificações
Motor
X132 Copperhead; 132 cubic inches (2,163 cc); 56° Fuel Injected V-Twin; 4.4” Bore x 4.4” Stroke; One-piece Forged Crank; Journal Bearing Design
Força
Torque: > 150 Foot Pounds
Horsepower: > 132 BHP
Transmissão
Confederate Patented 5-Speed Close Ratio; Patented Output Shaft Bearing Support System
Chassis
3” 120 Wall Hard Steel Backbone; 3” 120 Wall Hard Steel Down Tube; Hand Tig Welded Fabrication
Front: Custom Marzocchi RAC 50mm Fork; Rebound and Compression Adjustable for Low and High Speed Actuation
Rear: Custom Race Tech Coil-Over-Shock; Rebound and Compression Adjustable for Low and High Speed Actuation
Rodas/Pneus
Carbon Fiber; Front: 3.5” x 17”; Rear: 6”x 17”.
Front: Pirelli Diablo Rosso 120/70 ZR; Rear: Pirelli Diablo Rosso 190/55 ZR
Front: Dual Beringer 4 Piston AEROTEC Radial Calipers; Dual Beringer AERONAL Floating Stainless Steel Discs
Rear: Single 2 Piston Brembo Monobloc Caliper; Cross-drilled Brembo Stainless Steel Disc
5.75” Round LED Headlamp; Integrated High Beam, Low Beam, Running Lights; LED Tail Lamp, Brake, Running Lights, Blinker System
Confederate Proprietary Design; Deep-drawn Steel; 4.75 Gallon Capacity
Painel
Motogadget Precision Analogue Tachometer; Digital Speed, Status
Wheelbase: 62.5” ; Rake: 23.5 Degrees; Trail: 3.8”
Peso 500 lbs
Site Oficial
Empreendendo
