VTX 1300S
ENGINE
Engine Type 1312cc liquid-cooled 52-degree V-twin
Bore and Stroke 89.5mm x 104.3mm
Compression Ratio 9.2:1
Valve Train SOHC; three valves per cylinder
Carburetion Single 38mm CV
Ignition Digital with three-dimensional mapping, two spark plugs per cylinder
DRIVE TRAIN
Transmission Five-speed
Final Drive Shaft
CHASSIS / SUSPENSION / BRAKES
Front Suspension 41mm fork; 5.1-inch travel
Rear Suspension Dual shocks with five-position spring-preload adjustability; 3.7-inch travel
Front Brake Single 336mm disc with twin-piston caliper
Rear Brake Single 296mm disc with single-piston caliper
Front Tire 140/80-17
Rear Tire 170/80-15
DIMENSIONS
Rake 32.0 degrees
Trail 144mm (5.7 inches)
Wheelbase 65.7 inches
Seat Height 27.35 inches
Dry Weight 662.0 pounds
Fuel Capacity 4.8 gallons, including 1.0-gallon reserve
OTHER
Emissions Meets current CARB and EPA emissions standards.
Available Colors Black, Titanium, Dark Red Metallic, Metallic Blue
Model ID VTX1300S
VTX 1300 Series - Especificações
- Administrador
- Administrador
VTX 1300R
ENGINE
DRIVE TRAIN
Final Drive Shaft
Rear Tire 170/80-15
DIMENSIONS
Rake 32.0 degrees
Dry Weight 669.0 pounds
OTHER
Model ID VTX1300R
ENGINE
DRIVE TRAIN
Final Drive Shaft
Rear Tire 170/80-15
DIMENSIONS
Rake 32.0 degrees
OTHER
Model ID VTX1300R
- Administrador
VTX 1300C
ENGINE
DRIVE TRAIN
Final Drive Shaft
Rear Suspension Dual shocks with five-position spring-preload adjustability; 3.6-inch travel
Front Tire 110/90-19 M/C
Rear Tire 170/80-15 M/C
DIMENSIONS
Rake 32.0 degrees
Trail 149mm (5.9 inches)
Wheelbase 65.45 inches
Seat Height 27.46 inches
Dry Weight 641.0 pounds
OTHER
Available Colors Black, Dark Red, Pearl White, Pearl Dark Blue, Pearl Bright Green
Model ID VTX1300C
ENGINE
DRIVE TRAIN
Final Drive Shaft
DIMENSIONS
Rake 32.0 degrees
OTHER
Model ID VTX1300C
- Desvirtuador
style..
farol bem bonito
farol bem bonito
