GV650 Aquila Sports EFI 2010 - Especificações na Austrália
Dimensions & Dry Mass
* Overall Length (mm)2,430
* Overall Width (mm)840
* Overall Height (mm)1,150
* Dry Mass (kg)220
* Wheel Base (mm)1,700
* Seat Height (mm)705
* Ground Clearance (mm)160
* Frame TypePerimeter Cradle
Engine
* Type90° V-twin DOHC, 4 valves per cylinder
* Cooling System Liquid Cooled
* Displacement (cc)647
* Bore x Stroke81.5 x 62
* Compression Ratio11.6:1
* Max Power60kW @ 9000rpm
* Max Torque67Nm @ 7250rpm
* LAMS Max Power40kW @ 8500rpm
* Lubrication Wet Sump
* Starting SystemElectric
* Emissions Euro 3 Compliant
Capacity
* Fuel Tank (litres)14
Transmission:
* GearsConstant Mesh 5 Speed
* ClutchWet Multi-Plate
Chassis:
* Front Suspension41mm USD adjustable rebound and compression
* Rear SuspensionDual shock / adjustable preload
* Front Tyre120 / 70ZR - 18 59W
* Rear Tyre180 / 55ZR - 17 73W
* Front BrakeSemi-Floating 300mm twin discs with dual piston calipers
* Rear Brake270mm single
Warranty
* WarrantyTwo-year, unlimited kilometres
*Images are for illustration purposes only. Some items featured may be Hyosung accessories. Model year is identified by the 10th digit in the VIN code
Fonte: http://www.hyosung.com.au/cruisers/gv650-aquila-efi/
