GV650C Aquila Classic EFI - Especificações na Austrália
Dimensions & Dry Mass
* Overall Length (mm)2,470
* Overall Width (mm)960
* Overall Height (mm)1,135
* Dry Mass (kg)229kg
* Wheel Base (mm)1,690
* Seat Height (mm)675
* Ground Clearance (mm)160
* Frame Type Perimeter Cradle
Engine
* Type90° V-twin DOHC, 4 valves per cylinder
* Cooling System Liquid Cooled
* Displacement (cc)647
* Bore x Stroke81.5 x 62
* Compression Ratio11.6:1
* Max Power47kW @ 8250rpm
* Max Torque58Nm @ 7500rpm
* LAMS Max Power47kW @ 8250rpm
* Lubrication Wet Sump
* Starting SystemElectric
* Emissions Euro 3 Compliant
Capacity
* Fuel Tank (litres)17
Transmission:
* GearsConstant Mesh 5 Speed
* ClutchWet Multi-Plate
Chassis:
* Front Suspension41mm Conventional
* Rear SuspensionDual shock / adjustable preload
* Front Tyre120 / 80 - 16
* Rear Tyre170 / 80 - 15
* Front BrakeSemi-Floating 300mm single discs with 4 piston calipers
* Rear Brake270mm single
Warranty
* WarrantyTwo-year, unlimited kilometres
*Images are for illustration purposes only. Some items featured may be Hyosung accessories. Model year is identified by the 10th digit in the VIN code
Fonte: http://www.hyosung.com.au/cruisers/gv650c/
