V-Star Classic 650 - Especificações
- Administrador
2008 Yamaha V-Star Classic 650
Category: Cruiser
Specifications
Engine
Type: 40-cubic-inch (649cc) air-cooled 70° V-twin; SOHC, 2 valves/cylinder
Bore x Stroke: 81mm x 63mm
Compression Ratio: 9.0:1
Carburetion: 28mm Mikuni CV carburetors
Ignition: TCI
Transmission: 5-speed; multiplate wet clutch
Final Drive: Shaft
Chassis
Frame: Steel; hidden shock
Suspension/Front: Telescopic fork; 5.5-in travel
Suspension/Rear: Single shock; adjustable preload, 3.9-in travel
Brakes/Front: Hydraulic disc, 298mm
Brakes/Rear: 200mm drum
Tires/Front: 130/90-16
Tires/Rear: 170/80-15
Wheels: Laced
Dimensions
Length: 96.5″
Width: 36.6 in.
Height: 43.5 in
Seat Height: 27.9 in
Wheelbase: 64 in
Ground Clearance: 5.7 in
Dry Weight: 505 lb
Fuel Capacity: 4.2 gal
Available only in:
USA
- Registrado em: 14 Mar 2008, 07:55
Que linda esta moto!
alguém sabe se tem chances de vir para o Brasil?
