Raider - Especificações
Raider S
Engine
Type 113-cubic-inch (1854cc) air-cooled V-twin OHV, 4 valves/cylinder
Bore x Stroke 100.0 x 118.0mm
Compression Ratio 9.48:1
Carburetion Twin-Bore electronic fuel injection; throttle position sensor
Ignition TCI
Transmission 5-speed,multiplate wet clutch
Final Drive Belt
Chassis
Frame Double cradle
Suspension/Front Telescopic fork; 5.1-in travel
Suspension/Rear Swingarm; 3.5-in travel
Brakes/Front Dual hydraulic disc, 298mm
Brakes/Rear Hydraulic disc, 310mm
Tires/Front 120/70-21
Tires/Rear 210/40-18
Wheels 5-spoke cast
Dimensions
Length 101.2 in
Width 36.4 in
Height 45.9 in
Seat Height 27.3 in
Wheelbase 70.9 in
Ground Clearance N/A
Dry Weight 692 lb
Fuel Capacity 4.1 gal
Other
Warranty 1 Year (Limited Factory Warranty)
Raider
Engine
113-cubic-inch (1854cc) air-cooled V-twin OHV, 4 v 100.0 x 118.0mm
100.0 x 118.0mm 9.48:1
Ignition TCI
5-speed,multiplate wet clutch Belt
Chassis
Frame Double cradle
Wheels 5-spoke cast
Dimensions
Length 101.2 in
Width 36.4 in
Height 45.9 in
Seat Height 27.3 in
Wheelbase 70.9 in
Dry Weight 692 lb
Other
bem bonita... esta eu não conhecia...
se tu for ver... ela lembra o estilo da M800 ou seja... se aproxima de uma sport-custom dá pra ver que usa pneus e aros com estilo esportivo... ou invés dos clássicos raios... :wink:
luisasilveira
Registrado em: 22 Jun 2007, 15:12
legal esse escapamento em curva, nunca tinha visto um assim.....
