Stratoliner S - Especificações
- Administrador
Engine
Type 113-cubic-inch (1854cc) air-cooled pushrod 48-degree V-twin
Bore x Stroke 100mm x 118mm
Compression Ratio 9.5:1
Carburetion Twin-bore fuel injection, w/throttle position sensor
Ignition Digital TCI
Transmission 5-speed, w/multiplate wet clutch
Final Drive Belt
Chassis
Suspension/Front 46mm telescopic fork with adjustable preload; 5.3” travel
Suspension/Rear Single shock, link-type; 4.3” travel
Brakes/Front 298mm hydraulic, dual discs
Brakes/Rear 320mm hydraulic, single disc
Tires/Front 130/70-18
Tires/Rear 190/60-17
Dimensions
Length 101.6”
Width 43.3”
Height 59.6"
Seat Height 28.9”
Wheelbase 67.5”
Ground Clearance 6.1”
Dry Weight 758 lb.
Fuel Capacity 4.5 gal.
Other
Warranty 1 Year (Limited Factory Warranty)
- Administrador
Engine
Type 113 cubic-inch (1854cc) air-colled, pushrod 48-degree V-Twin
Final Drive Belt
Chassis
Suspension/Front 46mm telescopic fork with adjustable preload; 5.3" travel
Suspension/Rear Single shock, link-type; 4.3" travel
Dimensions
Length 101.6"
Width 43.3"
Height 59.6"
Seat Height 28.9"
Wheelbase 67.5"
Ground Clearance 6.1"
Dry Weight 758 lb.
Other
- Administrador
Engine
Final Drive Belt
Chassis
Dimensions
Length 101.6”
Width 43.3”
Height 59.6"
Seat Height 28.9”
Wheelbase 67.5”
Dry Weight 758 lb.
Other
